strict type def cohesion dot
@hiNI wrote:
As mentioned above, if I make it myself, will there be a penality if the COERSION dot appears?
hiNI.
If you make them yourself, the coercion dot should not appear.  If it does, you messed up somewhere.  Make sure that if you make a typdef'd control to actually use it, and not re-create it.
Bill
CLD
(Mid-Level minion.)
Message 11 of 16
(804 Views)
@crossrulz wrote:
First of all, it is COERSION dot.
I always thought it is coercion dot.
Message 12 of 16
(802 Views)
I spelled it correctly.  Do I get a kudo?
I know, that was shameless.  😉
Bill
CLD
(Mid-Level minion.)
Message 13 of 16
(797 Views)
Well, but the singular of the word is kudos, not kudo. You need to get everything right 😄
Message 14 of 16
(792 Views)
And that is why I am an engineer and not an English teacher.
Message 15 of 16
(784 Views)
But at least it's listed as a bastardization of the word "kudos".  😉
Bill
CLD
(Mid-Level minion.)
Message 16 of 16
(775 Views)
