string control input charecter to upcase charecter?
Cool find, thank you.  I use key down? in my VI's to disallow alpha characters in phone numbers, etc.   I'll have to check those, too.
Message 11 of 19
(1,814 Views)
Hi, ZWired1,
My friend take your attached VI, and wire the CtlRef in the event case to get its value property, then convert it to uppercase. It works fine but key repeat condition.
I'm still a little confused and do not understand these clearly. I have to study more Smiley Mad
Message 12 of 19
(1,809 Views)
oops
Bill
CLD
(Mid-Level minion.)
Message 13 of 19
(1,788 Views)
I would do it like this.  This event gets fired before the value is displayed in the control.
Edit: added key repeat.
aputman
Message 14 of 19
(1,765 Views)
Friends. Thanks for your kindly support!
Message 15 of 19
(1,723 Views)
I don't use filters enough in my events.
Bill
CLD
(Mid-Level minion.)
Message 16 of 19
(1,703 Views)
Using the accepted solution, the value gets written to the control twice, once as a lower case and once as an uppercase.   You can actually see it (barely) if you do a key repeat.  This may not be a problem if the VI is small and using very little of the CPU but may become more noticeable during high CPU usage.
aputman
Message 17 of 19
(1,688 Views)
so what is your alternative?
Message 18 of 19
(1,674 Views)
it's posted above....using filter events.
aputman
Message 19 of 19
(1,670 Views)
