string selection
Is there any else way to make this string selection much more easy without using these many case structure any thing which can take all strings and gives one output of the string which got selected randomlyCapture2.PNG
(4,157 Views)
Hi anjaney,
what about an array of strings with a simple IndexArray function???
(4,130 Views)
Can you please explain with a diagram sir i am not able to understand
Regards
Anjaney
(4,123 Views)
Accepted by Anjaney
Hi Anjaney,
as written before: place your strings into an array and use IndexArray to select one of them!
(4,119 Views)
Thank you sir for help
with regards
Anjaney
(4,115 Views)
