subpanel for vi in memory
Hey all,
I have a subvi in a project that I would like to insert into a subpanel. To complicate things, the vi is called directly elsewhere in legacy code that can't be easily changed (simulated by the false case structure at the bottom). Is there any way I can still call and run the subvi in the subpanel when it is loaded elsewhere?
(2,821 Views)
Accepted by ATE-EGNE
Try making your subVI reentrant. Right-click it, properties, execution and select Shared Clone reentrant execution or Preallocated clone reentrant execution.
Edit: since your sub contains an event structure you must use the Preallocated Clone setting.
Ben64
(2,812 Views)
There we go! Thank you for being here and awesome!
(2,781 Views)
