subvi and array of clusters
I want to make multiple sub-vi’s clones and each one gets its own cluster from an array of clusters. My problem is that I want to have the subvi’s do this during runtime and, so far I have not found a reliable method to this approach.  Is there a to tell within subvi clones which copy it is?
I'm using 8.6
Any help would be very much appreciated.
Mike
(3,220 Views)
Are you using VI templates, or are you using re-entrancy? In what way does the "copy number" relate to which element of the array of clusters that the VI should use?
(3,218 Views)
I'm using reentrant for the subvi's so each one has its own memory and would like each cloned subvi to have a seperate cluster in the array. It really doesnt matter the order just that each one has it own cluster.
(3,203 Views)
I would just put an input terminal on the subVI called "index".  In your main VI, wire up a different constant to each instance of the subVI.  First instance, wire up a zero.  Second instance, a one.  And so on.
(3,199 Views)
I discided to the parse the subvi clone name, and that lets me know which subvi I'm in .
Thanks everyone for all your help.
(3,181 Views)
