switch case like C
Hi all,
          Is it possible to use loop like switch case in C. Suppose one of my process generate numbers, like 1,2 ,3 4 n all, so if it generates 2 I want to perform task mentioned in event 3, if 2 then it should perform task mentioned in event 2. Please help me in this issue
Message 1 of 14
(4,677 Views)
sounds like state machineSmiley Wink
Message 2 of 14
(4,676 Views)
Use event structure
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 14
(4,675 Views)
@Omi_30 wrote:
Hi all,
2 - 2
3 - 3
Do you want for 2 for 2 and 3 for 3?
--Ranjeet
Message 4 of 14
(4,673 Views)
Thanks for the reply.
 But in event structure it is accepting with Button only. When tried with Button (Value Change), the proper event gets called, but when tried with Integer generated by process, then it is not working, Can you get some example.
Message 5 of 14
(4,670 Views)
If one simple addition in previous step generate 2, then Event structure should execute task in Event 2..like this so on..so not getting how to handle the Event source as this generated integer
Message 6 of 14
(4,668 Views)
like in C , if input to Switch case is Integer 2, the Case :2 will get executed.So same thing I want to do in LV.
But dont know how to use this integer as Event source in event structure. Did succefully event structure with buttons normal as taking Value change.
I am new to LV Smiley Surprised
Message 7 of 14
(4,666 Views)
Accepted by Omi_30
Here
--Ranjeet
Message 8 of 14
(4,659 Views)
Learn State machine.
You can trigger events for numeric values also usind Value ( signaling ) property but state machine will be better.
Make a decision in 1 state and based on the value switch to other states
Message 9 of 14
(4,658 Views)
Thanks a lot for the solution. Also is it possible to automate button pressing, suppose I am having one button but insted of user pressing that,can I controll the Button inside, using one Boolean?
Message 10 of 14
(4,638 Views)
