synchronize Motion velocity with DAQ analog signal
Hi Everybody
I am acquiring analog signals using hw trigger and external clock with C and A signals of a 1024 counts TTL encoder.
Now I want to measure the rotation speed of a shaft. I have a Flex-Motion board with which I want to read the velocity (or the same encoder), but I don't know how to synchronize each scan of the analog signals with the velocity signal for that instant.
I can´t use RTSI bus because my Motion board doesn´t have RTSI connector.
Software and hardware:
LabView 6i (v. 6.0.1.b3)
DAQ-Board: PCI-6023E, NI-DAQ 6.8.1, MAX 2.0
Motion board: PCI-FlexMotion-6C, NI-FlexMotion 5.0.1
Thanks a lot for your help.
(2,473 Views)
Hi chia,
with the hardware configuration that you have, I think it´s not posible to synchronize both boards due to you cannot share the same clock source (not RTSI on the motion board).
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/66e6f4ee7e0848d686256a55006...
Sorry for the delay 🙂
Regards
DiegoM.
(2,423 Views)
Diego,
 I desisted from using the FlexMotion board. Now I am measuring the shaft´s speed with external elements.
Anyway, thanks for your answer and your help.
Chia
(2,418 Views)
