tab container
Hallo,
      I have five graphs in 5 tabs placed in a tab container.  How to change the names of the tabs in a tab container automatically?  Or how to change the Caption for a Graph automatically with input being strings for these names. Thanks in advance.
Message 1 of 17
(5,927 Views)
Hallo,
 Please find the image for further reference
Message 2 of 17
(5,925 Views)
Accepted by harisskriss85_85
@harisskriss85_85 wrote:
Hallo,
      I have five graphs in 5 tabs placed in a tab container.  How to change the names of the tabs in a tab container automatically? [...]
Jim
Message 3 of 17
(5,912 Views)
Given that you seem to be early in your development process, may I suggest some alternatives to tabs. Tabs exacerbate problems like complicated code, and can cause a variety of update problems -- especially with graphs.
1. Instead of switching between graphs on multiply tabs, have one graph and simply select which data you you want to display in it.
2. Use subpanels to improve the modularity of your application by turning the logic required to generate each graph into a separate process. (The link in my signature shows how to do that.)
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 17
(5,898 Views)
It works!! Thanks alot
Message 5 of 17
(5,885 Views)
Hallo Mr.Mike,
 I could not find the link you mentioned. Thanks
Message 6 of 17
(5,880 Views)
Hallo Mr.Mike,
It is a link to he blog.
Message 7 of 17
(5,876 Views)
Hallo Mr.Jcarmody,
 Please find the attached image showing the error..when I tried to incorporate the steps you mentioned in my code.
Message 8 of 17
(5,858 Views)
Will go through it. Thanks
Message 9 of 17
(5,857 Views)
Hallo Hariss,
die Fehlermeldung ist doch sehr eindeutig: die Property darf zur Laufzeit nicht geschrieben werden…
Message 10 of 17
(5,847 Views)
