table
yes it is easy to fill a table that what i already did in my VI the only problem is that i cant clear the table after a whole measurement
a data of previous measurement stays in memory of table, try my VI and you see everything is working do a stop
and you will see the previous measurement appears again.
I see that someone had the same problem but did not find the solution
Message 31 of 38
(2,511 Views)
Hi drek,
Because you didn't incorporate our suggestions into your VI!
do a stop and you will see the previous measurement appears again.
Wrong! When you stop your VI and restart it the shift register is initialized with an empty array, so old data is lost…
(The table itself keeps the old data UNTIL you press your "append" button. That's the way YOU programmed it…)
Message 32 of 38
(2,505 Views)
here almost same problem, solution in a private message:
http://forums.ni.com/t5/LabVIEW/table-reset/td-p/2491688
Message 33 of 38
(2,494 Views)
Why do you keep reverting back to what we keep telling you does not work?
GerdW's solution found here is what you need.  You just had your Append logic flipped (ie swap your True and False going into the Select function for the Append).  Since you have data constantly coming in, you should not use the event structure.
Message 34 of 38
(2,465 Views)
Accepted by topic author drek1234
checked it again and it works 🙂 thx for having patience and spending so much time on me
glad it works.
Message 35 of 38
(2,458 Views)
You should really mark GerdW's post that I previously linked to as the solution.  It was the first to show you what you really needed.
Message 36 of 38
(2,452 Views)
i ll try if i can
Message 37 of 38
(2,445 Views)
If you just click on Options, you can unmark the solution you gave.
Message 38 of 38
(2,435 Views)
