take over last values as standard in an .exe
how can I take over programmatically the last values as standard values, so that they appear again as start-values when I open again the .exe ?
              Magnus Riede
(2,549 Views)
Magnus,
one possible way to implement that is using *.ini or cfg-files and VI-Server. In a "StartupVI" you can load the file, set the defaultvalues for your main-VI. After finishing work, you can call a "ShutdownVI" saving all current values from the mainVI back into the file.
Norbert B.
Norbert
Expert: Geometry
(2,548 Views)
Thank you very much, Norbert, it works fine Smiley Very Happy
Magnus
(2,531 Views)
