text to text machine translation
Isn't this an opportunity to use a dictionary?
Jim
Message 11 of 22
(1,045 Views)
__________________________________________________________________________________________________________
TiTou wrote:
Oh... that won't happen with the VI I gave you.
But you could add some code at the end to save all the attributes into a file and at the next start load the attributes from the file.
I'm home now so I can do it... but you could have a go, it's not that hard, and come back here if you have specific questions.
Good luck!
Should I create a sub vi or can i put the code in the diagram itself?
Message 12 of 22
(1,036 Views)
I think creating a subVIs is a good practise, but depending on how this "translation" functions will be used in your application you might want to create a set of functions (subVIs) that could be used throughout your app.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 13 of 22
(1,029 Views)
No idea... I have to say I've never used or event have a look into that palette... Shame on me... What does it do and what is it based on?
Epictetus
Antoine Chalons
Message 14 of 22
(1,027 Views)
Well in a nutshell I want to create a VI the would translate an entered english word e.g "Hello" to its Chinese equivalent. But as I understand Labview can't display chinese text as it displays "?" on the string
Message 15 of 22
(1,024 Views)
I have to say I've never tried Chinese, but I know Russian works and I would be surprised if NI hadn't done anything to support Asian Language... that's a huge market 😮
Maybe this can help you.
Epictetus
Antoine Chalons
Message 16 of 22
(1,006 Views)
________________________________________________________________________________________________________________________________________
CLD son of CLD
thank you  =D
Message 17 of 22
(998 Views)
Here's another way to localize your application.
PassaMak is an API for realising multi-lingual user interfaces in labview.
Jim
Message 18 of 22
(981 Views)
Jim
Message 19 of 22
(979 Views)
Hello again guys, I've done some editing with the database.vi that is posted in this discussion. It now saves the data to a file and if ever I press the Stop button and play it back again it still gets the translations. However, if I close Labview entirely and open it again, the saved data is gone and I have to add translations again. Pls Help 😐
Message 20 of 22
(961 Views)
