there is some way to know when LabVIEW finished to dend data (through RS-232) ?
i need to build program in labview that read the status of ESP300 controller continuousness.
additional, i need to send data to the controller when user push O.K. button.
1)how i can know when labview finished to send the data   through  RS-232 cable ?
2)it is possible that i will read status and send data at the same time ?
   if not what i need to do ?
thanks
(2,397 Views)
you fist need to know how the controller uses serial communication, maybe you need to send a read command to get data from the controller, in that way, yo need to write data to the serial port first, then read the serial port.
You could use a sequence  to write first, and read later. But you need to put delays between the comands
Write --> Delay --> Read --> Delay
The second delay is because you will put the sequence inside a while loop.
To send data when you press a button you can use a case structure to send this data when you press the button, and the case is true. When the case is false it read fro the controller.
(2,381 Views)
