tile window left and right
    I would like to have the tile window left with front panel and right with block diagram by default whenever open the vi.
How to do it?. is there any settings available?.
Kalyan
Message 1 of 12
(4,647 Views)
Hi Kalyan,
press Ctrl-T after opening the VI... AFAIK there is no default setting for this behaviour (and I wouldn't use nor want it...).
Message 2 of 12
(4,643 Views)
Obviously that will not be usefull when you are doing a big code... Maximize it and use it...Smiley Happy
Message 3 of 12
(4,631 Views)
O.K Thanks. I have one more query.
I have user defined VI in my folder. I would like to see in "Search Palettes". How to do that?
Is there any shortcut key to toggle "Search Palettes"?.
Message 4 of 12
(4,622 Views)
Hi Kals,
put those "user defined VIs" in your user.lib...
Message 5 of 12
(4,619 Views)
may i add llb file also inside user.lib?
may i include directory inside the vi.lib?
Is there any shortcut key to toggle "Search Palettes" window?.
Message 6 of 12
(4,610 Views)
Hi Kals,
you may add also llbs to the user.lib. I wouldn't stay away from adding folders to the vi.lib, it's the "LabVIEW-internal" function library!
Try Ctrl-Space to search for functions :smiley-wink:
Message 7 of 12
(4,607 Views)
Ctrl-Space is opening Quick drop.
I would like to know if i open "Search Palettes" i would like to know the short key to toggle it.
Message 8 of 12
(4,599 Views)
Is it possible to add my folder in the Labview settings. so that it can be listed in the "Search Palettes"
Message 9 of 12
(4,597 Views)
Hi Kal,
as said before: add your folder to the user.lib! Read the text in the options-> palette tab on how to do that!
Why use Search Palettes, when there is QuickDrop available?
Message 10 of 12
(4,594 Views)
