time delay between trigger and data acquisition
Hi, I am using NI PXiE-6368 as a tool for data acquisition. In my experiment, I use an external digital trigger to start taking measurements from a thermistor.
However, before the experiment, I want to find out the time that elapses between the detection of the trigger signal, and the start time of the Data acquisition.
Is there a way to do this?
(4,312 Views)
So there is a trigger that enables DAQ and you want to know what the delay is between your trigger and the first sample?  Do I understand your question correctly?
(4,278 Views)
Yep, that is exactly the question. I want to write a code to find out the delay, if that is possible.
Thanks.
(4,265 Views)
Accepted by SohamSaha
Here's the kind of thing I'd configure to get a precise measurement of the time from a t=0 trigger signal until
the actual first A/D conversion.   It may be overkill for a temperature measurement, but should get you on
the right track.
-Kevin P
(4,250 Views)
