timer+counter
Can someone please back save the counter plus timer vi to 8.5?
Tim C.
1:30 Seconds ARRRGHHH!!!! I want my popcorn NOW! Isn't there anything faster than a microwave!
Message 11 of 17
(2,881 Views)
Message 12 of 17
(2,869 Views)
would like to take this topic, ask for help. VI and have a need to implement it as a time counter.In other words, I need a code that shows the execution time and the total time. Can you help me? Thanks
Message 13 of 17
(2,647 Views)
Message 14 of 17
(2,647 Views)
I have to do this:
1. Turn on LED A,  then turn on LED B.
2. Turn on Beep then turn off Beep ( How to make beep in VI).
3. Count duration time in 1 or 2 (about 100-1000ms). I use LabView 8.6.
Thank a lot
Message 15 of 17
(2,511 Views)
Could you please send me this vi in labview version 8.2
Thanks for your help!!
Hetal
Message 16 of 17
(2,425 Views)
I've got an issue with the timer+counter.vi previously attached:
I have placed the timer+counter within a subvi that reads two signals from two sensors as an input from the main vi (i.e., Displacement (mm) and Uncorr Force (kN)), that are constantly read until I enter in the timer+counter loop: within such a loop the signals freeze and they unfreeze once the count is complete. Why does this happen and how can I avoid the freezing of the signals?
Many thanks!
Message 17 of 17
(1,286 Views)
