timing in case structure
Its clear, i have a push button, when its triggered on, it should green the led (which occurs, no problems), but when triggered off, it should turn off the led immediately, (which doesnt happen), how is it done ?
Message 1 of 18
(5,851 Views)
It's not easy to understand what your problem is with such a short description, can you post your VI or a screenshot of the block diagram so that it's easier for us to help you?
Trying to help
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 18
(5,850 Views)
uhhh, i forgot to attach it sorry.
Message 3 of 18
(5,848 Views)
do you have put your case structure inside a loop??????
Message 4 of 18
(5,840 Views)
explain more please. alok.p
Message 5 of 18
(5,834 Views)
if u have place your code inside a while loop ( for example ) the loop will continiously execute.
the true case waits for 5 sec. and then executes .
Rings any bell????????????
Message 6 of 18
(5,830 Views)
i understand , but how the loop will continously execute if the button is on its outside
Message 7 of 18
(5,824 Views)
Accepted by B4S3M
try "Event Structure" for reacting on events.
Message 8 of 18
(5,822 Views)
Yes the loop will not execute continiously, that's it .....remove timing vi and then you can see the action is executing as you want.
typically in your vi you are pusing your button and the only time you get for it is when waiting in true case.
Message 9 of 18
(5,820 Views)
i want different reactions, if boolean true, wait 5 seconds and execute, if false, then reset immediately, whats hard on that ?
Message 10 of 18
(5,810 Views)
