to convert 7.0 Labview version the cylinder example from 3D picture control
Hello!
I've tried to download the package 3D picture control, but i can't use it because is made for labview 7.1 and higher. Someone can convert the example to build a cylinder (from this package) to labview 7.0 and post it?
I f someone has an example code to build a cylinder instead of not being from the package it doesn't mather.....post it too.
Thank you in advance
Larson
(3,116 Views)
Here is a 3D cylinder in 7.0 format.
(3,111 Views)
I modified the file to make N-sided 3D extrusions. Now you can make triangles,squares,...
(3,103 Views)
This version lets you taper the object from zero to full size.
(3,097 Views)
First of all, thanks for your helping. I want to ask you for one more thing, do you have the code similar than the first code to make a closed object, i want to build a cylinder but with the two circumferences at both side, do you mena what i want to say?
thank you very much
(3,091 Views)
I guess what you are saying is that you don't want to be able to see thru the cylinder?? I haven't figured that one out yet.
(3,085 Views)
You can see through the cylinder if you change the % transparency of the object.....at 30%-40% you are able to see what there are inside the object....if you build the code please post it
Best regards!
Larson
(3,070 Views)
