total number of peaks in a signal
Hi Henrik_Volkers
Thanks for your instant reply and by the by, that's not my homework. I've been working on this for more than a month trying my own solutions.
I thought I can get the total number of peaks without using any formulas (MATLAB script), but I have a problem in solving it.
So please excuse me if there is any trouble.
Message 11 of 14
(694 Views)
I have attached a VI and an acquired signal.
If the value of N=13, then I get No. of peks is 72, increasing N gives higher value of peaks.
Kindly let me know how to adjust the value of "N" for "FOR LOOP" in order to get the number of peaks.
 Thanks in advance.
Good Day Smiley Happy
Message 12 of 14
(688 Views)
@SAIbme wrote:
Hi @1984,
Thanks for your reply.
Kindly be more specific about implementing the equation which you have suggested " speaking x(i) is a peak IF (x(i-1)<x(i)) AND (x(i+1)=<x(i))" .
Can it be implemented using MATLAB script?
Please suggest me an idea for it.
Hi SAIbme,
looks like (discrete) calculus to me:
if the first derivate f'(x) of your input signal f(x) changes it's signum as described by 1984, this change indicates a peak.
In the following example the peak would be indicated at x = 25
see also: https://forums.ni.com/t5/LabVIEW/Detecting-peaks-in-blood-pressure-waveform/m-p/2419090#M746711
Alex
Message 13 of 14
(674 Views)
Hi friends,
I would like to thank 1984NapDynamiteHenrik_Volkersalexderjuengere
For their replies and suggestions.
Finally, I've got the correct output.
Thank you friends once again.
Message 14 of 14
(642 Views)
