traditional DAQ on LV2009?
after doing an installation of LV2009 and it's DeviceDrivers I missed the traditional DAQ functions... Even trying to re-install (or update) the traditionalDAQ didn't work.
So:
Is TradDAQ support dropped starting from LV2009? I couldn't find information on this in the upgrade notes...
Possible workaround:
Described here: Working in the opposite direction as described I copied the files from my LV8.6 to the LV2009 folder...
(3,668 Views)
Gerd,
This lists NI-DAQ (Traditional) 7.4.4 as being a compatible driver version.  No mention as to how to install it with 2009.
Message Edited by Wayne.C on 08-20-2009 08:55 AM
(3,656 Views)
Accepted by GerdW
hi gerd,
i found a knowledgebase which says what to do in this case:
Traditional DAQ Palette Does Not Appear In LabVIEV
http://digital.ni.com/public.nsf/allkb/7B916CC4A067997D862574BB000E2AB5?OpenDocument
with kind regards
patrick
(3,624 Views)
Hi Patrick,
thanks for the link. It gives the same information as the link in my question, but focused on error description...
(3,606 Views)
