turn array of integers into a ranges list
I am looking for a clean way to turn an array of integers into a ranges list.
turning thistshurtz_0-1591732469530.png into this tshurtz_1-1591732544909.png or at least this tshurtz_2-1591732838357.png
I am hoping there is a VI already somewhere in the bowels of Labview that I can use as this is essentially what is happening in the case structure selector label if you list many integers and some are consecutive.
Anyone know where I might find this magic vi? I can write my own but if its already available all the better.
(4,221 Views)
I doubt it,  you'll likely have to code it yourself.
Should be a fairly simple loop with just a couple case structures.
You need to know when you are starting a run of numbers, ending a run of numbers, or still in the middle.
Step through element by element.  If the next element is equal to the current element + 1, you know you are in a run.
(4,212 Views)
I know the case structure will automatically do that for you.  I wonder if there's a way to leverage that information somehow...
Bill
CLD
(Mid-Level minion.)
(4,180 Views)
I made this ages ago.
(4,164 Views)
I am sure this has been solved before here in the forum. But should be trivial to implements if we can make certain assumptions:
  • Is the array guaranteed to be sorted?
  • Are there no duplicate elements?
Assuming the input is clean, this might work for you. There are many other ways.
(4,090 Views)
Accepted by tshurtz
Thanks again 
(4,063 Views)
As I said, it really depends how clean the input array is and additional code might be needed.
One request thought. Please give a VI a new name when attaching a new version. It can lead to serious confusions if a thread contains multiple different VIs, all with the same name.
At this point I would suggest to turn it into a malleable VI (vim), correctly accepting any integer datatype. (only available in recent versions, but alone worth the upgrade!)
(4,054 Views)
