turn array of integers into a ranges list
I am looking for a clean way to turn an array of integers into a ranges list.
turning thistshurtz_0-1591732469530.png into this tshurtz_1-1591732544909.png or at least this tshurtz_2-1591732838357.png
I am hoping there is a VI already somewhere in the bowels of Labview that I can use as this is essentially what is happening in the case structure selector label if you list many integers and some are consecutive.
Anyone know where I might find this magic vi? I can write my own but if its already available all the better.
(4,204 Views)
I doubt it,  you'll likely have to code it yourself.
Should be a fairly simple loop with just a couple case structures.
You need to know when you are starting a run of numbers, ending a run of numbers, or still in the middle.
Step through element by element.  If the next element is equal to the current element + 1, you know you are in a run.
(4,195 Views)
I know the case structure will automatically do that for you.  I wonder if there's a way to leverage that information somehow...
Bill
CLD
(Mid-Level minion.)
(4,163 Views)
I made this ages ago.
(4,147 Views)
I am sure this has been solved before here in the forum. But should be trivial to implements if we can make certain assumptions:
  • Is the array guaranteed to be sorted?
  • Are there no duplicate elements?
Assuming the input is clean, this might work for you. There are many other ways.
(4,073 Views)
Accepted by topic author tshurtz
Thanks again 
(4,046 Views)
As I said, it really depends how clean the input array is and additional code might be needed.
One request thought. Please give a VI a new name when attaching a new version. It can lead to serious confusions if a thread contains multiple different VIs, all with the same name.
At this point I would suggest to turn it into a malleable VI (vim), correctly accepting any integer datatype. (only available in recent versions, but alone worth the upgrade!)
(4,037 Views)
