txt file
Hello everybody,
I have created a txt file with the function "write in file" how can i introduce a line between the different values that i am saving ?
Example i have this : 0,43240,455660,876666
and i want to have : 0,4324
                                0,455660
                                0,876666
Thank you for your help !
Bonjour à tous,
J'ai créé un fichier texte avec la fonction "écrire dans un fichier texte" et j'enregistre des valeurs de positions mais je voudrai aller à la ligne entre toutes mes valeurs comment puis je faire ?
Exemple : j'ai ceci : 0,43240,455660,876666
et je souhaite :
                                0,4324
                                0,455660
                                0,876666
Merci pour votre aide !
Message 1 of 8
(4,501 Views)
Use LineFeed (or CarriageReturn) instead of TAB, SPACE or comma!
Or create a 2D array consisting of 1 column per row instead of just one row.
Both answers may apply to your code - but you haven't shown that…
Message 2 of 8
(4,494 Views)
Accepted by marieanissa
You have to put the constant end of line( in Programation>>String) between the différents values.
SMIRES,
Message 3 of 8
(4,489 Views)
Great it finally works !!
thank you everyone 🙂
Message 4 of 8
(4,479 Views)
Now i have an other problem.
I want my computer reads the different lines and interprets it as each line is a value for a position of the platform how can i do this ?
thank you
Message 5 of 8
(4,458 Views)
Hi Marie,
Then you should read the text file line by line and interpret each line/value!
There is a function able to read textfiles line by line. And there are functions to convert tet to numbers. Well, there even is a function that reads a whole spreadsheet file (aka delimited text file) and converts it to numbers in one step!
What have you tried so far? Where are you stuck?
Where is your VI?
Message 6 of 8
(4,453 Views)
You could use the Read From Delimited File to get the array of values.
Or you can use Read From Text File, right-click on it and choose Read Lines, set the number of lines to read to -1 (read all) and now it will output an array of strings (each element is a line from the file).
Message 7 of 8
(4,446 Views)
Please marieanissa do not ask the same question at different places.
Lire-un-fichier-texte
Message 8 of 8
(4,432 Views)
