units with formula node
hi,
I have a little problem with the formula node. I am trying to multiply h (Planck constant) by c (speed of light), already defined in Labview. But i can't link them to the entries of a formula node because of the units.
By the way, i have another problem which is that if I want to write 6.63E-34 for h, i have an error and i think that it comes from "E".
Do you have any ideas ?
Thank you for your time!
(6,175 Views)
I didn't figure out how to deal with pre defined c and h constants but there is no problem with "E" anymore...
(6,172 Views)
Accepted by topic author christophe69000
You can use the Convert Unit function to get a unitless number. You just need to enter the units of the constant in the Convert Unit function. For example, for Planck's constant:
By the way, what is it that you're doing that you believe you need to use a formula node as opposed to just coding it in LabVIEW? Just curious.
Message Edited by smercurio_fc on 07-01-2009 11:24 AM
(6,149 Views)
I end up converting it to the units I want to use and then casting the units.
(6,136 Views)
Thank you smercurio!
To answer your question, i think that I could have coded my equations in LabVIEW without using a formula node, but in my opinion it would have been a bit heavy.
Tell me if i am doing wrong!
(6,119 Views)
Well, I'm not sure what you mean by a "bit heavy". The equivalen G-code would look like this:
Don't know if that's heavier than a formula node. I can say one thing: If you're going to be performing the calculation a lot then the G-code will most likely be faster since you don't have the overhead of the formula node.
(6,104 Views)
Ok! Then I will have to change my formula nodes for G-code, because the faster it is performed the better!
(6,100 Views)
