‎07-25-2013 08:27 AM
I am trying to use a USB 201 to measure a voltage signal. I bought the USB 201 card. But I do not see the card in MAX when I connected the card to the machine through USB. I have installed the drivers.
‎07-25-2013 09:44 AM - edited ‎07-25-2013 09:57 AM
Hi Hotha
Do you mean the NI 9201?
Which drivers have you installed?
Please create and attach a 'MAX technical report' which will detail which software and hardware you have installed in the system. (Open MAX, File > Create Report > MAX technical report)
If you do actually mean the 'USB 201' then it will not show up under MAX, as it is not produced by National Instruments and the driver is not part of the DAQmx package. Instead you need to download and use the drivers and LabVIEW driver from their website.
Kind Regards
‎07-25-2013 11:51 AM
Thank you. It makes sense. Does VISA from labview read the USB 201? Or do I have to use the USB read functions
‎07-26-2013 04:28 AM
You need to go to http://www.mccdaq.com/software.aspx, download the 'MCC DAQ CD 6.26' and then use the 'ULx for NI LabVIEWâ„¢ 2.02' driver for LabVIEW to interface with the board.
Kind Regards
‎07-26-2013 09:14 AM
Hi try to install it from MCC website and maybe try to check with DASYLAB also![]()
‎07-26-2013 10:18 AM
Just to be clear, the USB-201 from Measurement Computing is not an NI device, and will not show up in the NI Measurement & Automation (MAX) device list.
To use it with LabVIEW, install the ULx for NI LabVIEW from the MCC CD that came with the device. You need to install and run instaCal to initially detect and configure your device before you can use the ULx. Visit the www.mccdaq.com web site for more information, including software downloads and the Knowledge Base. The KB has lots of articles that may apply. You can also request technical support from Measurement Computing, if you need more help.
To use the USB-201 with DASYLab, you need the most recent DASYLab driver that will ship next week with DASYLab 13.
