usb 6009 signal generation
Hello !!
Can any one suggest me how to generate a pulse of 3V/0V at output pin (a01) to switch transistor..
requirement is : 1ms - 3V and 400ms -0V continously..
Using NI-USB 6009
thanks in advance!!!
(2,806 Views)
Accepted by topic author gsantu
The short answer is that you cannot do that with the USB-6009. The analog outputs of the device are software timed and the 1 ms pulse width is too fast for software timed outputs. Depending on the computer, OS, other software activity, and perhaps the phase of the moon, you can only expect AO update rates of 100 Hz to  a few hundred Hz and there may be considrable timing jitter at those rates.
You need to get a DAQ device with hardware timed AO.
Lynn
(2,778 Views)
Helllo !!
Thanks for your reply....
Am satisfied with your answer, But i wonder if  it is  possible to generate using digital port(PO.0) of USB-6009 with the mentioned requirements ???
thanks in adv !!
(2,757 Views)
The digital port of the USB-6009 is also software timed and will have the same limitation.
Lynn
(2,726 Views)
