use irig for waveform t0
I would like an IRIG timestamp to be part of the time information (t0) in the waveform data type that I get from my data acquistion.  Is there a more efficient way of doing this other than the VI I've enclosed?
Message 1 of 15
(4,113 Views)
Missing attachment.
Message 2 of 15
(4,093 Views)
sorry, try again
Message 3 of 15
(4,087 Views)
still attempting ...
Message 4 of 15
(4,086 Views)
attachment not working ... can I send it via email?
Message 5 of 15
(4,085 Views)
Message 6 of 15
(4,078 Views)
How about changing T0 of each waveform instead of adding an attribute?
Message 7 of 15
(4,069 Views)
okay.  Is there a way I can sync the IRIG time from my timing card to the timer on the DAQ card?  Then I wouldn't have to be replacing t0 at every DAQmx Read.
Message 8 of 15
(4,058 Views)
Can you give us some more information about your particular hardware setup?
Message 9 of 15
(4,039 Views)
The timestamp is not obtained from the DAQ card. The DAQmx driver gets the timestamp from the OS. Can you update the windows date/time from the irig card? That is probably the best you can do without going to NI-Sync hardware/software.
Message 10 of 15
(4,032 Views)
