use labview to read an Excel file to some control and add a checkbox for each row
  As the subject say,I need to use labview to read an excel file,and show it in some control,such as mclb;then ,I should add an checkbox for each row,enable me to choose the row i want.What should I do ? Many Thanks.
(4,113 Views)
@guiming wrote:
What should I do ?
What have you tried?
(4,112 Views)
to answer your question:
- read an excel file
- show it in some control, such as a MCLB
- add an checkbox for each row
- choose the row you want
Hint to make it easier: I wouldn't use checkboxes, as the MCLB already allows to select rows by mouseclick…
(4,079 Views)
   I can read an Excel file to a sheet ,but I have no idea how to add a checkbox for each row.
(4,064 Views)
Accepted by guiming
Sometimes all you need to do is Google. https://decibel.ni.com/content/docs/DOC-25000
http://www.labviewing.com/check-box-in-multicolumn-listbox/
(4,061 Views)
Thank you very much!
(4,057 Views)
