using an event structure to reset a boolean control with ring menu value change
I am trying to get two boolean buttons to reset when the value of a ring menu changes.  For this I am using an event structure set to execute with a ring value change.  However I have other code that needs to be executing while the event structure waits for the value change.  I place my event structure inside the while loop the buttons reset as expected but my other code does not run (except at the moment of value change). If I place it outside the loop the rest of the code functions as expected but the buttons do not reset.  Any help you can offer is much appreciated.
(3,158 Views)
Accepted by grabeer
ADD TIME OUT EVEN AND GIVE 100 MS TIMEOUT.
Add event case-application-timeout
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,153 Views)
I knew there had to be an easy solution.  Thanks so much!
(3,149 Views)
try this
Regards
Freelance_LV
TestAutomation Consultant
(3,144 Views)
Oh! I am late!
but i gave a different solution, though
Regards
Freelance_LV
(3,143 Views)
