values written to a table are not preserved
Hi GerdW
ok, I still need to find out how to use a shift register to hold the output table.
you are rightstop condition is not needed in the For loop
Best Regards
Hakam
Message 11 of 15
(1,233 Views)
Hi Hakam,
a shift register works the same in every loop, no matter if FOR or WHILE:
Message 12 of 15
(1,226 Views)
Hi GerdW,
by the way there is no option 'use shift register' for case structure
And the reason why I connect False to the conditional stop of for loop was because of:
Message 13 of 15
(1,218 Views)
Hi Hakam,
I never said "shift registers go with a case structure" - I told you "shift registers go with any loop"!
As this is a VERY basic LabVIEW thing: Did you take the free resources for LabVIEW beginners offered by NI on their website?
Wrong!
The reason for that FALSE constant is: you accidently enable the stop condition of the FOR loop! Disable that feature and you will not need an additional boolean constant!
Message 14 of 15
(1,213 Views)
@hbs_80 wrote:
Hi GerdW,
In that case you can use a Feedback node which (to a limited extent) can be thought of as a "Loopless SR".
Ben
Message 15 of 15
(1,210 Views)
