*.vi files names opening strange from the forum in LV8.5?
Has anyone seen this strange behavior?  When I open a *vi direct from the forum the file name gets corrupted as follows:
For example from this "AO timedloop1.vi" to this "AO%20timedloop1[1].vi" as the default file name.  I understand that 0x20 is the space character but why is LabVIEW doing this to the files?  -SS
(2,976 Views)
I can't say that I've seen this. Where was this VI posted?
(2,974 Views)
Right here. This is the second time I've noticed this.  -SS
(2,972 Views)
I see this quite frequently opening 8.2 vi's from the forum, see attached screen shot of 3 recently opened files in LV startup screen.
(2,961 Views)
I don't think that LabVIEW is doing this. If you open it from the browser the file is saved to a temporary directory. The browser replaces the space by %20 (ASCII escape because spaces are not allowed in URLs) and the [1] is appended because the file already existed in your temporary directory.
Daniel
(2,950 Views)
I agree with Dan.  Happens all the time.
I now use it for when I post a solution with the same name ..  I just up the number a notch..
Example[1].vi becomes Example[2].vi
(2,931 Views)
I know about the [1] suffixes - I see those all the time, and yes, that's caused by the files residing in the browser's temp folder. I just haven't seen the %20. I'll pay more attention to see if I see it.
(2,917 Views)
