vi.lib/LabVIEW Targets/FPGA/ECAT Missing dependecies.
Hi!
I am trying to make a build of the Scan Engine Custom Device I got all the needed components but I still got some missing VIs. This VIs should be in vi.lib/LabVIEW Targets/FPGA/ECAT/SubVis/FPGAParsingVIs. I check my sistem and I don't have a vi.lib/LabVIEW Targets/FPGA/ECAT Folder. Does anyone know where can I find this VIs? Maybe I'm missing some package?
Thanks!
Andrès.
(4,032 Views)
NI-Industrial Communications for EtherCAT
(4,006 Views)
Thanks for the reply.
I already have this, I have the lasted version(20) I uninstalled and reinstalled but the problem persists. I'm using labview 2018. Any ideas?
(3,998 Views)
Accepted by ayiep
Solve it by deinstalling the ECAT Driver 20 and installing the 18.5.
(3,978 Views)
I'm having the exact same issue with LV 2019 SP1.
I followed the steps here
Online Slave Device State for NI EtherCAT Chassis Stays Empty - NI
Didn't fix it
I installed Industrial Comms 21.5 didn't fix
I uninstalled and reinstalled didn't fix it
Looks compatible
NI-Industrial Communications for EtherCAT and LabVIEW Compatibility - NI
Please help
K
(2,840 Views)
