vision error
hello............
     We are using Evaluation Version of NI vision, I am facing a problem while building EXE of my project, NIvision popup's an error "  Upgraded Evaluation version".
please suggest me a solution.
      please tell me the details about the licensed version  of vision .i am using windows 7 OS and LabVIEW 2010 32bit.
(3,928 Views)
Have a look at  this
Thanks as kudos only:)
(3,926 Views)
I'm not 100% sure but I think that one of the limitations of the evaluation version is that you can't build an EXE.
That means you will have to carry on using the source code to use your application.
If you wish to deploy your application to another computer, even if you could build an EXE you would need a run time licence for VDM (vision development module) to be able to run your application.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,923 Views)
try to remove all check marks in the build spec app properties as shown below:
This might help.
Andrey.
(3,911 Views)
what will be the cost for installing licensed version of vision
(3,895 Views)
Take a look at the different purchasing options
Epictetus
Antoine Chalons
(3,888 Views)
