vision
I'm new to lab view i have a problem in connecting imaging source camera in lab view. I tried to connect camera from the instructions provided in www.ni.com there is a small issue in Devices and interfaces here i attached the screen shots. Kindly do the needful.
(4,338 Views)
This message board is for threads discussing the operation of the forums themselves.
You need to post your question in the LabVIEW forum, or send a message to the moderator to have it moved there.
(4,329 Views)
I already asked the moderator to move this thread.
(4,321 Views)
Accepted by navaneetha
Do you have image acquisition software installed (imaq, imaqdx) , what type of camera have you plugged in (gigE, firewire, usb, cameralink.....).
what have you done so far?
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,274 Views)
Hi Paul Falkenstein
Thanks for your reply.
I have installed NI-IMAQ 4.7.3, I'm using Imaging source USB camera what has to be done next?
R Rakesh Reddy
(4,238 Views)
You need imaqDX installed for usb cameras, IMAQ is for cameralink cards.  Make sure under software you have installed imaqdx drivers.
Paul Falkenstein
(4,202 Views)
If  you want to open and operate the image,your computer must have been installed the vision model successfully.
(3,511 Views)
