wait until the acquisition is done
Hi Fird, have you seen the last program that i sent you. Work with that you can count the edges in train of pulses and passe to another state of a state machine when the number of pulses are reached. The program that you sent me its not able to count the edge of the pulses. Please tell me if the program that i sent you latter works as you want.
saci
Message 11 of 21
(1,946 Views)
Hi SaCi,
Thanks for your assistance.
Yes, it helps me a lot.
Btw, since this problem actually for my acquisition project, I would like to go back on the original VI.
I would like to get your suggestion on the array problem.
The data only show like below:
The next value will replace the previos value.
My objectives is to put all the data in the array. Do you have any idea? Do I need to use a loop?
Thanks.
-Fird-
Message Edited by Fird on 07-06-2009 04:24 AM
Message 12 of 21
(1,932 Views)
You overwrite the array all the time, that's why you get only one result.
Yo should concatenate succesive array's using for example the "Build array function as showed in the attached screen shot where MyData is the array that contains all the data and New Data is the data from each loop iteration.
Be sure to select "Concatenate inputs" whenyou right click the "Build array" function.
Hope this helped 🙂
Message 13 of 21
(1,920 Views)
Hi Alain,
I did not get you. Can you explain using a VI attached together here.
Thanks.
Message 14 of 21
(1,911 Views)
I could if you provide me a LV 8.5 version Smiley Happy
Message 15 of 21
(1,907 Views)
Ok. Please find the attachment below.
Thanks a lot.
Message 16 of 21
(1,904 Views)
Accepted by Fird
Modified version in attachment 🙂
I simulated two DAQ cards with the MAX and tested the VI.
It looks good 🙂
Hope this helped
Message 17 of 21
(1,898 Views)
Hi Alain S,
Thanks a lot. I will try it now.
-Fird-
Message 18 of 21
(1,896 Views)
Hi Alain,
I just curious. What make my VI become 2D not 1D as yours. See figure below.
Fird.
Message Edited by Fird on 07-06-2009 08:00 AM
Message Edited by Fird on 07-06-2009 08:03 AM
Message Edited by Fird on 07-06-2009 08:04 AM
Message 19 of 21
(1,893 Views)
Hi Alain,
I manage to solve it. But I don't know what cause the problem.
Thanks a lot.
Fird
Message 20 of 21
(1,887 Views)
