wave
I need help with this project
Create a vi that shows on the screen a signal. It signal must be selected from senoidal, square, triangular and you have to be able to change the amplitud and frequency.
(3,635 Views)
Go through LabVIEW basics. Then start with example finder to use some of the waveform generation functions...
(3,624 Views)
(3,605 Views)
I suggest you start out with a loose wire.
(3,585 Views)
