waveform chart
hi,
i need help how i can add control Boolean and create a property node so i can select either the strip or sweep. i have a hard time to figure it out. thank you
(4,050 Views)
Accepted by jiji_830
If the input of UpdateMode is 0 then it is strip and if it is 2 then sweep modestrip sweep.PNG
CLD Using LabVIEW since 2013
(4,031 Views)
You also need to right-click the property and change it to "write".
(4,003 Views)
thank u
(3,997 Views)
thank u
(3,995 Views)
