web-publish for external window
hi
Is there any ways to web-publish the external video window created by IMAQ (vision).thank
(2,514 Views)
Hello.
You can publish an IMAQ window using the LabVIEW Web Publishing Tool. If you configure your VI to be accessed as a Remote Panel, you will be able to see it on the client machine with the LabVIEW run-time engine installed. Just go to Tools->>Web Publishing Tool. . . to configure your VI for use as a remote panel.
Colin C.
Applications Engineer
Colin Christofferson
Community Web Marketing
Blog
(2,514 Views)
