Hello.
You can publish an IMAQ window using the LabVIEW Web Publishing Tool. If you configure your VI to be accessed as a Remote Panel, you will be able to see it on the client machine with the LabVIEW run-time engine installed. Just go to Tools->>Web Publishing Tool. . . to configure your VI for use as a remote panel.
Colin C.
Colin Christofferson
Community Web Marketing
Blog
