why does my subvi open when I open my main vi?
I have main VI that calls a subvi within it. When I open the VI from windows explorer, the subVI opens with it. This also happens when I try to run it. I don't have the subVI set to open when called. I can post the VIs if needed. Thanks!
(3,328 Views)
Accepted by rpscott02
1. Check Window Appearance in VI Properties;
2. Check SubVI Node Setup by right click SubVI on the block diagram of your main VI.
(3,322 Views)
Yup. The Window Appearance was the problem. This was driving me mad! Thank you!!
(3,271 Views)
