write in spreadsheet ActiveX
hi all,
i have a spreadsheet activeX control. i am able to read the it's contents by giving cell range.Likewise I need to write on it.Anyone having idea.
Thanks in advance....
(5,740 Views)
You have to specify the cell no. and data. Same way as you are reading.
(5,731 Views)
You will need to open the references to the correct worksheet and add the range data. see the example
Tim
GHSP
(5,717 Views)
If you're using activeX controls to work with Excel, you might find this VI useful - it can handle writing pretty much anything into any cell or range of cells, though formulae may have to be entered individually.
Never say "Oops." Always say "Ah, interesting!"
(5,715 Views)
hi
Here i have attached the screen shot of the code for Read and write in activeX Spreadsheet.In that, Read is working. Wite method is not working but it doesn't shows any error.see my attachment....
(5,711 Views)
Try giving the starting cell only on the range input i.e C3 not C3:D6
Tim
GHSP
(5,709 Views)
Like this
Tim
GHSP
(5,706 Views)
