writing text file in while loop
Here is my question about writing text data to a file in a while loop...worded best I can.
I have an Init case where I have the user choose a file path and name. I take the ref out and then I have data that is being written to the file. The loop will take 40,000 pieces of data write them to the file and go back to the get data case to collect another 40,000 data points. But when I open the file, I only get a file as big as 430KB. I'm not sure but can somone show me an example of pulling analog data from a DAQ Assist, doing a calculatoin on it, writing it to a file and repeating that by adding it to the same file at the end of the previous data?
(4,727 Views)
Take a look at the attached VI's.  Did you have your data set to append?  This could be your problem.
(4,710 Views)
Accepted by Tony88a
See attached for LV 8.0 versions
(4,706 Views)
