wsn 9791 Firmware
I am trying to update the firmware on my WSN 9791. I can see the 9791 in Max and NI network browser.I am using MAX version 4.7.7f0. THe 9791 current firmware version is 1.0.1. I have the file ni9791fwROM_LV861_LV2009. Once I click on Update Firmware, I click yes and I see: Check The WSN Gateway Firmware Consistency...After a couple of seconds an error message shows up saying:A communication error occured while updating the WSN. Reboot and try agin.
I tried to reboot but it does not work.
ANy help is muvh appreciated.
Message 1 of 12
(4,000 Views)
Aside from the firmware issue, I am having trouble adding nodes as well. The Add Node button is greyed out. I have reset things, reboot etc and read through many pages on NI support, but no luck. I might have to return the whole thing. I cant afford to pay $1500 for SSP either....
Message 2 of 12
(3,988 Views)
See attached screen shots.
Message 3 of 12
(3,985 Views)
One more attacement....
HELP
Message 4 of 12
(3,984 Views)
Hey wv,
give me a little bit to look this over and see what I can find
Jesse Dennis
Engineer
INTP
Message 5 of 12
(3,975 Views)
Hi Jesse,
Any help would be much appreciated. Let me know if you need more info.
Thanks!
Message 6 of 12
(3,973 Views)
Accepted by wv
Hi wv,
It looks like this is an network connection issue. For most software installs our hardware reboots into an installation mode and tries to reconnect to the computer to actually start installing software. At this point there may be trouble re-connecting to the PC. In practice this problem manifests exactly as you have described.
Here are some troubleshooting steps:
-drop your firewalls
-turn off antivirus
-set your device to have a static ip address (see this kb).
-turn off wireless on your PC
If your computer has multiple ethernet ports or multiple cards it can also cause problems like this.
let me know how these go
Jesse Dennis
Engineer
INTP
Message 7 of 12
(3,968 Views)
Ok it works now. Here is what I did. Turned off wireless card in Laptop and rebooted with firewall off and virus scanner off. Windows security asked to block or unblock connection. I chose unblock, went to MAX and I was able to run firmware update. Also allowed me to add nodes. I then proceeded with uploading firmware to nodes with bootloader. I got an error message (see 5.png) I chose Continue, upgraded all nodes without trouble.
Now my next problem is adding targets and devices in LabVIEW 2009 FDS. See 6.png. When I right click on Project in Project Explorer I only have the option to click on New...
Thanks for your help, much appreciated!
Message 8 of 12
(3,961 Views)
Glad to hear it worked. Try right clicking on "Untitled Project" instead. This tutorial should help you.
Jesse Dennis
Engineer
INTP
Message 9 of 12
(3,958 Views)
Jesse,
Thats what I did. Sorry, I did not clarify that very well.
In step 2. (Right-click on the Project item and select New»Targets and Devices...) of the tutorial I only have New, thats it.I am missing the "Targets and Devices" and "Target Folder"
Message 10 of 12
(3,955 Views)
