x axis keeps going back to autoscale
What is the datatype of your chart data? It almost seems you are graphing data that contains absolute time information (waveform, etc).
Either graph plain data or change the x-scale property to "ignore waveform time stamp on x-axis".
It would really help of you could attach your VI. It does not matter if we are able to run the code. You should attach it anyway so we can see what you are doing.
Message 11 of 11
(778 Views)
