xcontrol reference error out of memory
This seems like a bug but I wasn't sure if there was anything I could do to prevent this from happening.  I am using LV2009 and whenever I accidentaly wire an xcontrol reference to somewhere that it doesn't belong, the program freaks out and throws an out of memory error.  After a few clicks I am finally able to select the broken wire, and delete it.  Is there something I can set in the xcontrol or Labview that would prevent them from trying to do whatever it is that it is that they are trying to do?
(3,696 Views)
Hi Jimbo,
I am not seeing this behavior with an xcontrol reference that I set up on my system. Does this happen with a reference to any xcontrol, or is it only certain ones? Could you post your VI so that I can see if the same thing happens?
Stephen S.
Applications Engineering
(3,663 Views)
I've only tested it on two very similar xcontrols, and then on a new xcontrol. I created a new xcontrol, with no editing (just saved it right away), and then a new vi and inserted the xcontrol into the vi. To simulate the error I was seeing, I wired up the reference of the xcontrol to a string.  Normally this error occurs when I accidentally wire the reference up to the error terminal of a property node.  Trying to right click on the wire brings up an out of memory error as shown below.  Attached is the code that produced this error.
Perhaps I should let my boss know that my computer is too old (~ 1 year) and needs to be replaced 🙂
(3,661 Views)
HI JimboH,
I will  give this a try and let you know what I find out. Kinda late here so I will be checking it out tomorrow.
Joshua B.
(3,641 Views)
Hi JimboH,
Nice and easy to reproduce. I have filed Corrective Action Request  (CAR) 186664 to R&D for further investigation. I do not have a better work around other than
not to wire the reference into an indicator at this time.
Joshua B.
(3,616 Views)
