xy chart - yscale.range error
I'm having an issue with programmatically settting my y-scale range on an xy chart. I'm programatically setting the x and y scale fit to 0 (do not autoscale), then setting the x-scale and y-scale range. The x-scale works fine but when trying to set the y-scale i get error 1077 - invalid property value. I read on the forums a possible fix by disconnecting the y-range control from the typedef but still no luck.
I'm using LV2012 SP1. Any help would be appreciated.
Thanks!
(3,367 Views)
Can you post your VI please ? (or a little VI showing the problem)
(3,357 Views)
(3,346 Views)
Accepted by DavidT
Your problem is not autoscale, you have set your minor increment to be 0. Change it to something sensible for X & Y axis.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,340 Views)
Thanks, I knew it would be something I simple...Smiley Frustrated
(3,333 Views)
Whoops, slow typing again, said the same thing as .aCe. Please disregard.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(3,330 Views)
