yokogawa wt3000
hi! i'm new here
i have a question about yokogawa wt3000.
i have to control yokogawa WT3000 with LabView via Ethernet.
the communication works perfect.
i have downloaded the driver(ykwt3000.llb)
there is a lot of VIs, how should i use them to get data from yokogawa for Example: speed, U, I...
thank you for your help in advance
Message 1 of 21
(4,907 Views)
If you have a valid driver, you should have got some documentation telling you whats what.
Also, if you downloaded the driver from NI website, you will also find examples there. Just do a search.
Message 2 of 21
(4,895 Views)
i did it, and that's my VI.(please see the attachment)
Message 3 of 21
(4,891 Views)
my question now, what should i do to read the torque for example from yokogawa
Message 4 of 21
(4,884 Views)
Instead of trying to use a LabVIEW driver VI, do you even know how to do what you want using the front panel on the instrument?
Message 5 of 21
(4,865 Views)
i'm reading at the same time the users manual WT3000.
Message 6 of 21
(4,863 Views)
Hi KaramWT,
I just downloaded the driver from Yokogawa's website.
You have some examples in the LLB
Message 7 of 21
(4,845 Views)
oh thanks! i'll try it
Message 8 of 21
(4,838 Views)
it is a good idea to start with an example
Message 9 of 21
(4,836 Views)
about the example2.VI, are all the data ( what i need to read ) contained in preset(1,2,3or4)?
what i know, the items that are specified in preset 1 are:
U,S,Q,Phi,I,P,Lamda, FreqU and FreqI
but if i want to get more items in preset1, should i select them?
sorry for my bad english 🙂
Message 10 of 21
(4,830 Views)
