yokogawa wt3000
the example is based on VISA communication using Write and Read VIs. Have a look at this NI-VISA Overview
Message 11 of 21
(1,683 Views)
The example VI sets the display configuration and reads measure value for the WT3000.
This VI is an example of how to use the WT3000 subVIs programmatically.  This VI sets the display and Preset item, reads the measure value.
see the VI and SubVIs documentations
Message 12 of 21
(1,680 Views)
you mean application example2.vi
Message 13 of 21
(1,670 Views)
ok ok got it thanks
Message 14 of 21
(1,665 Views)
yes example2.vi
It is a good example 🙂
Message 15 of 21
(1,654 Views)
hi!
did you get some data from your yokogawa wt3000?
Message 16 of 21
(1,649 Views)
I'm right now not working with yokogawa wt3000 but the example should work
Message 17 of 21
(1,639 Views)
i have an other question.
i want to read in labview the motor efficiency.
i found out that there are two VIs (Config Efficiency Udef.vi and Config Efficiency Eta.vi)
which one do i need?
Thank you for your help in  advance
Message 18 of 21
(1,632 Views)
where did you find the two VIs?
Message 19 of 21
(1,615 Views)
there are by:
Instruments-IO--->Instrument Drivers--->YKWT3000 Digital Power Meter--->Configure
Message 20 of 21
(1,607 Views)
