LabWindows/CVI Idea Exchange
layosh.b
Support HPC using GPU computing
Status: New
My 2000 dollar worth, run of the mill desktop PC has 4 teraflop of brute computation power hiding in 4 GPUs. None of which is accessible for my programs I develop in Labwindows.
Shame!
With the release of the new OpenCL it is possible to generate a "platform independent" GPU computing library. That would place Labwindows on the same or better footing than Labview that already has some GPU computing support.
The advantages are obvious: huge gain in data processing speed, real-time application with streaming data,  pattern-recognition (video) applications, image processing, data-parallel tasks in (technical) modeling arena.
I am playing with some optimization algorithms (genetic algorithms, evolutionary algorithms) that benefit and show amazing gains since they are ideal for data-parallel applications! Currently working on the specs for a new type of controller that would optimize several parameters to figure out the state of the tissue culture (expanding, producing, overgrowing, etc.) to maximize productivity and to calculate the optimal settings using evolutionary algorithms... Any complex process control could take advantage of this kind of applications -currently not available- because of computational limitations. Had a previous optimization task that would have taken 150,000 years to complete using a brute force algorithm on a "monofilament" CPU-based application. Converted it to a genetic algorithm and it gives me a good enough solution in 3-4 days on the same standard PC. Now, with GPU, that problem could be solved in fifteen minutes while expanding the evolutionary depth and finding better solutions using even more complex fitness functions.
Ask yourself what do you want: tinkering with the conveniences of the IDE that already does the job well enough; or open the door to new landscapes that could be conquered by using the simple elegance and effectiveness of LabWindows and the power of GPUs?
3 Comments
gdargaud
Active Participant
You should be able to link .o generated by CUDA with CVI, no ? No need to add complexity.
40tude
NI Employee (retired)
What about an OpenCL library ?
Regards, Philippe
Regards, Philippe proud to be using LabWindows since version 1.2
Layosh
With the new Kepler architecture andCUDA 5 toolkit capabilities (nclduingthe compiler support) the GPU is more accessible than ever! The issue is that other platforms move toward GPU support (including labview) and CVI rapidly becomes obsolete, far less powerful than the competitors. this also means that my investment into learning CVI loosing its value. If I need more processing power and move to new territories and solve computationally expensive problem, I have to leave CVI and eat the ugly frog: have to learn  Visual Studio instead of relyiong on a standardized, easy to undeerstand CVI environment and IDE. No question, CUDA works under visula Studio and Eclipse IDE too,finally  managed to compile under both; but it is a nightmare for me to comb together all teh pieces, the libraries, the dependencies, etc. between teh system. I do not want to spend my time to walk on this edge and chase down solutions for each of the problems that need to be solved before have something rally useful. CUDA support for CVI could be the solution, and NI is so good at making libraries simple and very useful, it would boost the market for it. Remember: only in the first week after making it public, more than 1 and half million programers downloaded CUDA 5.  that is a market, a big market, even though CUDA is difficult in itself. Combining CUDA with teh CVI tools, boosting some of the CVI libraries with GPU would give a superb tool into the hand millions of engineers!!! Millions!
