i would like to know information on how to use the STRUCTURE on CVI?
any advice or pdf doc to share
Are you referring to a "C" data structure?
If so I would recommencd looking at: http://http://www.gatesit.org/gitdownloads/C&DS.pdf
Just came across this post and noted that the link is not correct: the document can be found here.
