LabWindows/CVI
200279 DAQmx error
We see the DAQmx -200279 error during extended runs of continuous acquisition.  We can go for hours without seeing the issue.  I have attached the main blocks of our data acquisiton module (daq_code.c).
Some observations / comments:
  • Debug build
  • We saw much improvement setting sleep policy to VAL_SLEEP_MORE
  • The nSamples value in callback when error occurred appeared to be a value of 8 (at least in CVI debugger).  We had setup the callback to be called every 800 samples.
  • We do use remote desktop connections to view extended runs.  Although, it does appear that the issue occurred at least once when RDP was not being used.
  • Source module for DAQmx acquisition is built into a DLL.  The application and DLL share a thread safe queue.
Questions:
  • Is it advisable to override the default DAQmx buffer size?
  • Is it OK to assume that both DAQ1 and DAQ2 will have the same number of samples when Callback function is called?  (since they are synchronized in initialization)
  • Is there a way to ignore the -200279 error and not lose the proper order of samples based on channels
  • Could the counter task have any impact on AI tasks?
Thanks!
(3,829 Views)
Hi jharris66,
- You can change the DAQmx buffer size according to your needs.
- It would depend on the device itself, synchronization assures you that they will begin at the same time, but data availability depends on the hardware.
- You could make an exception for the error by handling it.
Please check the following documents to make sure that you can prevent the error from happening:
http://digital.ni.com/public.nsf/allkb/4159A4241B8A24B3862570EC007AB6B7
http://digital.ni.com/public.nsf/websearch/58C3BD58847B7AD286256F19007DEEE6?OpenDocument
Here you can find a way to cancel the error:
http://digital.ni.com/public.nsf/allkb/BF72229C53F7633386256EDD0069331B
Hope this helps
(3,791 Views)
